If you're having trouble with your Panasonic DVD recorder input not working, you're not alone. Many people have experienced this issue and it can be a frustrating one to solve.
The first thing to do is to check the cables and connections. Make sure that all the cables are securely connected and that the power is on. If the cables are all connected properly, then you may need to reset the DVD recorder.
If the reset doesn't work, then you may need to contact Panasonic customer service. They can help you troubleshoot the issue and get your DVD recorder working again.
It's always a good idea to keep your DVD recorder up to date with the latest firmware. This can help prevent issues like this from happening in the future.
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
Version
UP-317
Compatible Models
DMR-EH55S
Issues Addressed
Issues Addressed
Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
Resolves U71 error message caused by HDMI connection to Philips TV.
Improves DVD-Video playback of DVD+RW discs.
Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
You need a scart junction box this is a device that allows you to connect more than 2 devices together but you may find that the tivo will be affected by the cable box hope not but it might .. Regards Vortash
If the freeview box has a SCART output, connect that to either AV1 or AV2 on the Panasonic. To record, select either AV1 or AV2 as the input. Use the other AV to connect to the TV to playback.
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
