Check the rectifier diodes in the power supply for shorts and look at all the filter capacitors in the power supply. Look for puffy discolored and domed tops. All filter capacitors must have flat tops. Check the windings of the transformer for darkened or burnt spots and test for shorts in both the primary and secondary windings
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
More likely the output transistors. You can measure them (power disconnected) for short circuit between any of the 3 legs (base, collector, emitter) Otherwise you can try de-soldering the transistors from the circuit board and see if the amp keeps blowing fuses. If it doesn't blow the fuses, then its the output transistors, but make sure you also check for burn resistors and shorted drivers. If all of that is no help, then probably check your power supply and B+ rails for plus and minus voltage supplies.
