SOURCE: SAMSUNG LNS3251DC - RED POWER LIGHT IS ON BUT TV
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
SOURCE: Integra dtr-6.3 receiver: Red standby light
your receiver is having a power problem. The power supply board is defective that's why the receiver won't power up. Its receiving power but it cannot transfer the current to the necessary part of the receiver because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the capacitor might not come on.
This may have occurred as a result of power surge/irregular power supply/excess power supply entering into the unit. This is usually common with receivers and electronics as a whole.
If you know about electronic repairers, I would suggest that you open the receiver and read the power board/panel with a meter, detect the bad component and replace it.
But f you don't know about electronic repairers, take the reciver to the nearest repairman to fix the fault for you.
I wish you good luck.
SOURCE: my integra dtr 5.6 receiver
hi,
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
