You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
SOURCE: Janome 1600P quilting free motion sewes fine for a
Please ensure that you are uing the correct size needle for your that you are using. are you using a straight stitch needle plate. Please let me know what size thread and needle you are using
SOURCE: The thread keeps breaking while free motion
Tough one! Did the machine ever work when it left the shop? if the shop said its working and its been in 4 times there could be a communication issue. I use schmetz brand quilting needles and have found some threaedds are so poor quality they cause this problem. Try a BEST quality thread, size 40 or 50....no bigger to start. Some folks buy big cones of thread and by the time they are used up the thread is brittle and weak. Work slowly...set the speed controller on the front of the machine at 1/2 to 2/3 speed and hold the pedal down to get a even speed. Dont move the fabric to fast, a slow smooth movement is whats needed. Practice on the same fabric and backing as you are trying to sew on. Bring it back to the dealer and ask them to try it. then you will have a better idea of whats what.
Derek
SOURCE: I have a Janome 1600P
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
