If you've already replaced the lift motor on your Proform 400s Treadmill and the incline still won't work properly, there may be other underlying issues that need to be addressed. Here are a few troubleshooting steps you can try:
Check the wiring: Ensure that all the wiring connections related to the incline mechanism are secure and properly connected. Loose or damaged wiring can cause issues with the incline functionality.
Inspect the incline motor and gears: Examine the incline motor and gears for any signs of damage, misalignment, or obstruction. Ensure that the gears are engaging properly and that there are no obstructions preventing the incline from moving up and down smoothly.
Reset the treadmill: Perform a full system reset on your treadmill. This can often resolve minor software glitches or issues that may be affecting the incline function. Consult your treadmill's user manual for instructions on how to perform a reset.
Contact customer support: If you have followed the above steps and the issue persists, it is recommended to reach out to the customer support of Proform or the retailer from whom you purchased the treadmill. They should be able to provide further troubleshooting guidance or arrange for professional repair assistance if needed.
Remember to exercise caution when working with electrical components or performing any repairs on your treadmill. If you are unsure or uncomfortable with the process, it is advisable to seek assistance from a qualified technician or the manufacturer's customer support to ensure proper diagnosis and resolution of the issue.
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error
Probable Cause
Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action
Troubleshoot as errors 40 and 42.
Precor Error Code E2
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
Check the power cord to ensure
it is connected to the power supply and the treadmill if the power does
not stay on or does not turn on. Look at the circuit breaker, located
near the base of the unit, to see if the circuit was tripped. Push the
switch back in to reset the circuit.
Take the key out of the console,
wait a minute and place it back in the console to resolve issues with
the power turning on and off during use or if the console displays are
not functioning properly.
Remove the console key and press
the "Stop" button to turn off the "Demo" mode, which is often the
default setting when the treadmill is first purchased.
Reset the incline by holding
down the "Stop" and "Speed increase" buttons and putting in the console
key. Release the buttons and then press the "Stop" button, followed by
the down or up arrows for the incline. This step can be taken if errors
are occurring with the incline function.
5
Turn the treadmill "Off" and
unplug the unit if errors continue. Wait five minutes and then plug the
unit back on, insert the console key, and turn the treadmill "On." This
will reset the treadmill and should return to normal funcTION
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
