SOURCE: Download canon printer LPB2900
You can download the driver from here [click here]. You'll need to select the Operating System [o.s], If you have problem, let me know with more details about your computer. If you can at least let me know the Operating System running on your computer, I could help you better.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
SOURCE: download printer canon LPB2900 install printer
Click on the link below and then select your operating system and language to download the drivers and software for your Canon LPB2900:
http://software.canon-europe.com/products/0010177.asp
SOURCE: I have a new Dell PC with Windows 7 64 bit OS. My
Please get the correct driver here :
www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__mci9ie4
SOURCE: I can't print, printer spooler
Hi jolly_r_naci,
You may try the steps below to address the issue with the print spooler:
1) Open a Command Prompt window, type "net stop spooler" (no quotes).
2) Navigate to c:\windows\system32\spool\printers\
3) Once there, on the menu bar, click on Tools, Folder Options, View,
put a dot in the radio button on the 9th item in that list "Show hidden
files and folders", Click Apply, then OK,
4) Delete all files found in the ..spool\printers folder, if found.
5) Go back to command prompt and type "net start spooler".
Hope this helps.
Thank you for using FixYa.
SOURCE: My I900D Canon printer Prints But the paper is
Please follow the following steps. 1) Turn off the printer. 2) Shutdown the PC to which the printer is connected. 3) Remove the USB/Serial cable through which the printer is
connected to the PC and reconnect it back. And change the cartridge (Place a new cartridge instead of the old one) 4) Now switch ON the PC(only PC and not the printer) 5) Let the PC boot up and login to windows. 6) Now switch on the printer, PC should detect the printer
automatically now.
Now you
will be able to print.
