Televison & Video Logo
R
Robert Moore Posted on Feb 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio E70 C3 power button doesn't work
Remote works fine to turn the tv on/off but pressing the power button the back of the tv does nothing.
slammit
Level 2:
Habit-Forming:
  • Expert 85 Answers
  • Posted on Feb 12, 2017
slammit
Expert
Level 2:
Habit-Forming:
Answers
85
Questions
Helped
44199
Points
149
The button on the back of the tv is a multi function type. It can be used to turn on/turn off/change inputs. Press it once to turn on the tv, press and hold to turn off the tv. Look at page 11 of the owners manual for a full description of the switch.
Greenbrier International 110064 Universal 6 In 1 Remote code to program a Vizio tv
To program a Vizio TV with the Greenbrier International 110064 Universal 6 In 1 Remote, you can follow these steps:
  1. Turn on your Vizio TV.
  2. Press and hold the "Code" button on the remote until the LED light stays on.
  3. Use the number buttons on the remote to enter the code "11864" for Vizio TVs.
  4. Press the "Power" button on the remote to see if the TV turns off. If it does, press the "Enter" button to save the code. If it doesn't, repeat step 3 with a different code from the list below until you find one that works.
Other possible Vizio TV codes for the Greenbrier International 110064 Universal 6 In 1 Remote include:
  • 11758
  • 11756
  • 11742
  • 11740
  • 11738
  • 11687
  • 11670
  • 11587
  • 11365
  • 11136
Note: If you can't find a code that works for your Vizio TV, you can try the auto-search function on the remote. To do this, follow steps 1 and 2 above, then press the "Power" button repeatedly while pointing the remote at the TV until the TV turns off. Once it does, press the "Enter" button to save the code.
2answers
Vizio E60-C3. The picture is dimmed. One side is darker than other. What do I need to replace? T-con board, main board, led lights.
Try a Hard Reset first.
Note: To perform a hard reset on a Vizio Smart TV, you will need to use the remote.
  1. Unplug your router.
  2. Press the menu button on your Vizio remote.
  3. Navigate to System on the menu and select OK.
  4. Select Reset & Admin and select OK.
  5. Select Reset TV to Factory Defaults and select OK.
More items...
Mar 19, 2022
How to Hard Factory Reset a Vizio Smart TV - Alphr
Hard Reset VIZIO TV E60-C3, how to - HardReset.info
https://www.hardreset.info > devices > vizio-e60-c3
In the first place, you need to turn on your VIZIO E60-C3 TV. · Once the TV turns on, press the Menu button on the remote. · Now the Menu should appear on the ...
Smart remote
It is not the Remote. The problem is in the receiver section of the TV.
Vizio 55" smart tv e552vle no power or standby light!
Have you tried un plugging the TV for 10 minutes and seeing if that clears the lock up? This is a software issue I'm sure.
4helpful
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
3helpful
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
18helpful
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
2helpful
2answers
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
36helpful
4answers
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
