Question about Lexar Electronics - Others
HOW TO UNLOCK LEXAR MERMORY CARD - Lexar Electronics - Others
  • Lexar Master
  • 18,031 Answers
There is a little tab on that unit that slides back and forth. If the tab is missing, you need to use a piece of scotch tape to simulate the tab.
Posted on Feb 10, 2017
SOURCE:
Lexar sd card error, it is a 16gb Lexar sd card. When I put the card in my camera it says "card error-card is locked. Need to know how to fix this card.
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 21, 2014 | Lexar Electronics - Others
How to unlock memory card on digital camera?
Look on the side of the card, there is a switch. Just slide it and you will unlock your card.
Jul 19, 2011 | Lexar Professional High-Speed 2GB Secure...
Camera does not read memory card or put pictures on mermory card
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
May 01, 2011 | Cameras
None of my Play Station2 Tomb Raider games or Resident Evil PS2 Games will find my mermory card (So wont let me ave any games).it says each time that no mermory card is installed (When it is)\r\nI have...
In situations like that.. It sometimes helps to use an empty memory card.
If you have a memory card that you can delete everything off of.
Try that.. once the card is empty and clean, the games may recognize it..
Aug 17, 2010 | Capcom Video Game Consoles & Games
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
My lexar memroy card reads ''this card is locked''
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 27, 2009 | Lexar Professional High-Speed 1GB Secure...
How to unlock my 1GB lexar camera memory card
Look at your card to see if you may have broken the small tab off from the locked side. I noticed that my card looks different and I may have broken it off not knowing.
Feb 18, 2009 | Lexar Professional High-Speed 2GB Secure...
Mermory card for samsung moblie phone
the card actually inserts looking as though you are placing it in the mobile upside down. It will locate and lock into place. To remove after wards simply press in and it will jump out.
Easiest way to put music on it as mp3s is to copy them from a pc and then put the card into the mobile afterwards
Dec 27, 2007 | Samsung SGH-D600 Cellular Phone
Does not turn on
Get another battery - it is possible the replace is stale/old/dud. Check the cleanliness of the contacts on battery and the camera, a light polish with tissue- sometimes if the camera has not been used for a with a slight patina of dirt/corrosion will build up to prevent contact.
May 08, 2007 | Nikon Coolpix 2100 Digital Camera
Electronics - Others Logo
1,617 people viewed this question
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
