Kitchen Ranges Logo
K
Keith Nance Posted on Feb 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DO YOU HAVE A OVEN RACK FOR AVANTI ER24AW - Avanti Kitchen Ranges
Level 3:
  • Avanti Master 19,187 Answers
  • Posted on Feb 09, 2017
Avanti Master
Level 3:
Answers
19187
Questions
0
Helped
4345934
Points
82261
No! and neither does anyone else it appears. That unit is discontinued.
I NEED A OVEN RACK FOR A AVANTI MODEL ER24AW
That unit is no longer made and there are no parts in the USA or the EU
1helpful
Avanti G2002CW oven or broiler won't stay lit once ignited
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
Looking for parts for Avanti g20aw
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
4helpful
2answers
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
13helpful
3answers
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Top Avanti Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
