Kitchen Ranges Logo
K
Keith Nance Posted on Feb 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED A OVEN RACK FOR A AVANTI MODEL ER24AW - Avanti Kitchen Ranges
Level 3:
  • Avanti Master 19,187 Answers
  • Posted on Feb 09, 2017
Avanti Master
Level 3:
Answers
19187
Questions
0
Helped
4346399
Points
82261
That unit is no longer made and there are no parts in the USA or the EU
DO YOU HAVE A OVEN RACK FOR AVANTI ER24AW
No! and neither does anyone else it appears. That unit is discontinued.
1helpful
On my model #EW30EW65GS3 in the self cleaning cycle even tho I removed all the racks & the rack supports it keeps flashing remove racks
Hello. From what you're describing, there might be a problem with the rack switch. It is connected directly to the main oven display board at connector P10 for a single oven(See pic 3, left side, middle). On the double oven model, there will be a P12 connector near the same area. TURN OFF POWER TO THE OVEN BEFORE ATTEMPTING TO CHECK ANYTHING!! On the double oven display board, there will be a connector P10 and P12 for the upper and lower oven racks.The part number for the main oven display board is 7316516536 in case the switches are good. The rack switch part number for the upper and lower oven is 7318903403. The part number is the same for the switch in the single oven model. Note the designation on the exploded parts diagram as 14(with a circle around the part). I've included the last pic(the oven relay board) just for future information.The part number for it is 7316443919(dual oven relay board). If you are hesitant about attempting to troubleshoot the oven, definitely call for service! This can be an INVOLVED REPAIR requiring advanced troubleshooting. The connectors on the circuit board can be damaged easily as they are multi-pin devices. You will need a voltage/ohm meter with fine probe tips to perform continuity checks on the rack switch(s). I hope I helped you!
Sep 26, 2015 • Ovens
Parts I need a new Broiler Rack (P/N 21432) for Toastmaster toaster oven, Model 337. Mine doesn't have the convection oven as it is an older model.
My manual has 1(800)947-3744 Mon-Fri 8:00 am to 5:30 pm CST I have purchased a broiler pan from calling them in the past; now my unit just died yesterday so need to find another.
1helpful
Avanti G2002CW oven or broiler won't stay lit once ignited
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
Looking for parts for Avanti g20aw
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
4helpful
2answers
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Rival Microwave ..Model MT660 oven rack
Contact Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
13helpful
3answers
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Top Avanti Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
