SOURCE: 5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
SOURCE: Quadra-Fire Pellet stove-Pellet pot fills.
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Testimonial: "Thank you...don't know who Steve Tate is but will definitely look into Ignition Box replacement."
SOURCE: I have a King Pellet
If you have a hand held bottled type, propane torch, you could carefully try that. However, never ever use any type of liquid starter, like charcoal lighter fluid, kerosene, etc. All you want to do, is get a cup or so of pellets started burning hotly and let the auger take over feeding the fire from there.
Be extremely careful doing this.
Hope this helps you stay warm tonight.
SOURCE: Can I run a pellet stove off a generator its a
If you are just running the blowers and what not, then yes you can. Blower motors do not take more than between 200 and 500 watts or so, so you should be okay running the blowers.
