Garden Logo
G
Glenn Murray Posted on Feb 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda snowblower HSS928 2015 loses power under load
Robert
Level 2:
Habit-Forming:
New Friend:
  • Expert 78 Answers
  • Posted on May 02, 2019
Robert
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
78
Questions
0
Helped
62786
Points
148
Needs carburetor cleaned out ethanol in gas destroys them
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112282
Points
562
Rpms are too low at full throttle
2011 honda fit lose power a while driving
First check to see what the fuel pressure is. If it is too low, then you may have a restricted fuel filter or a bad fuel pump.
Cub cadet big country won't start in cold weather
The first cold startign in likely a choke problem.
The second all engines loose power under load.
Cub cadet are no usually high power machines.
Oct 12, 2014 • Garden
Why is my v8 surging while under load
govenor not set correctly. weak fuel pump diaphram.
Craftsman 179cc ohv 2 stage snowblower loses power in second stage throwing heavy snow
You should check for belt condition and adjustment. Under more load the auger/impeller belt might start to slip and would result in poor performance. For improved performance in wet slush there is an "impeller modification" that can be found with a web search. It's adding rubber wipers to the impeller blades and it does a great job of tossing that stuff out the chute instead of clogging it.
Feb 13, 2014 • Garden
My snowblower looses drive power when under a load
check drive wheel if chewed up or worn out replace
adjust cable or linkage tighter for drive
Honda engine snowblower wont stay running
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Snowblower wont start
Check out this YouTube Video. It will show you how to disassemble and clean the carb for the Honda HS520 snowblower.
http://www.youtube.com/watch?v=4i14aB6g798
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
1helpful
Interupted power
try installing new plugs, sounds like you you may have a fouled plug.  is the bike hard starting?
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
