SOURCE: my hp officejet 8500 printer sends a message that
This message occurs if there is a hardware issue with the ink system of the unit. Please contact the HP phone support or fill in a web form and the unit will be replaced.
Web for link :
https://h10025.www1.hp.com/ewfrf/wc/email?product=3752462&lc=en&cc=uk&dlc=en&lang=en&cc=uk
SOURCE: Power button is blinking and Carriage is stalled
there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
Testimonial: "I LOVE U MAN!! TNX FOR THE HELP! I HOPE I CAN BRING YOU PIE! OR SUMTIN' TNX SO MUCH ^_^"
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Testimonial: "superb"
SOURCE: How to reset ink levels on HP Officejet Pro 8600 Premium
shut of both the electrecity and the shut bottom press 10 minutes than replugg and start
