SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
SOURCE: oven door does not close completel. Oven light remains on.
if it closes when you push against it, replace the door hinges
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
SOURCE: frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
SOURCE: freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
