Sceptre Tv model X322BV
SOURCE: My sceptre 32" class LCD 720p 60hz HDTV x322BV-HD!
if that is brand new and still covers on warranty you need to do is get back to the dealer for repair or possibly replace
SOURCE: Samsung LN32c350 sound but no picture
Likely there isn't anything you can do on your own at home short of increasing the brightness through the menu. You probably have a bad IC that will have to be replaced by a technicion
SOURCE: SCEPTRE X322BV, HDTV BLUE LED COMES ON WHEN POWERING UP, BUT NO PICTURE OR SOUND
I have the X322BV-HD and with no warning had the same thing happen. I"ve scoured the net and found very little--just as here on this site. I just got off the phone with a tech support rep at sceptor and got the following information:
HOW TO DO A FACTORY RESET:
That didn't work for me. But the second option, a Power Cycle Reset did.
POWER CYCLE RESET:
The second option worked for me and it's back on working just fine. Hope this helps!
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
