The idea of installing cooktop can be intimidating After all you re dealing with either electricity or gas while simultaneously handling an expensive appliance The good news is...
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself. Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom. Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop. It's useful to have another person lift each end of the cooktop while you insert the bracket from below. Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
HI they just sit on the top with brackets holding from the underside or screwed in from under the top sounds like this was put in the tiled after they arestuck downfwith double sided tape as well some times , if nothing works you could go through the top it breaks like a car windscreen hope this helps
If it were me, I would go to Home Depot or Lowe's and get a small roll of metal strap with holes every 1/2". Should be an easy find and easy installation
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
