SOURCE: fault code
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
SOURCE: How do you reset a
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start
up.let it complete its routine (takes 2 mins or so).now the machine has
reset.select program as normal and retry
Hope this helps
