Epson r2400 Printer stopped working, red lights alternately flashing
Green light flashed,print head twitched and made just one noise,red ink out and paper out lights flashed alternately Print head never unlocked,cannot be moved.I unplugged the cable to the printer, I turned it on holding all 3 other buttons, unplugged power, turned it on. There is no paper or other obstructions noted,no overflowing ink. maint reset utility cant find the printer and the SSC service utility failed to set data for the SSC Service utility, The PC recognizes printer
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed ·Check empty or damaged ink cartridge ·Clean the dirty print head or replace missing or failed print head
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button.
Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
