I have a 1963 Seeburg jukebox that won't play the b side of the records. How do I fix it?
The machine will bypass the record when it should pick it up. Then it will return from the opposite direction, pull the record and the needle hits the aside of therecord.
Assuming it is an 830 Record (old mechanical, not the new computerized model). If it sounds like the motor is straining but the machine's mechanics are not working, then the machine has most likely seized from old, dried up oil.
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
The feed dog control is the knob at the very bottom front, right side of the machine. If the feed dogs are not dropping, most likely the machine needs a thorough cleaning and OILING! I use Tri-Flow Synthetic Lube.
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
check to make sure that the needle was put into the needle holder correctly all the way up into the needle holder--flat side of the needle to the back side of the machine if the machine still doesn't up the bobbin thread then it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
