If you wish to get more details visit the sites linked here. http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
SOURCE: Err7 in haier wahing machine
HOW TO FIX ERROR 7 PROBLEM!
This problem is quite common on these machines, especially just after the machine has been moved. As a previous poster has said, Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
SOURCE: Haier washing machine error 1 message does 1 mean
You need to close the machine door, thats what error 1 means :)
SOURCE: Error 4 ON HAIER WASHING MACHINE.
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
Error EC4 refers to the temperature of the air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
Ask the technician to
repair it.
Alternatively make a custom cycle with no drying cycle and hang dry the laundry. I usually do this myself as opposed to listening to it groan for 2-3 hours.
SOURCE: How to fix error f
Hi and weclome to FixYa, I am Kelly
An F54 code is a motor over current fault. This is caused by a severe load on the motor or a bad motor bearing.
To remove the error press Pause/Cancel twice. Before removing the error.. try and find out why the motor is hard to turn. There may be an article of clothing stuck at the top of the inner tub or between the inner and outer tub. (
If the unit has previously had an ld code (long Drain) this can also cause high motor currents if the water level switch allows the washer to spin when not completely empty. Usually an ld code is associated with something stuck in the pump / pump inlet or possibly a bad pump.
Thanks for choosing FixYa,
Kelly
