I have the stand assembled, just need instructions on the.bracket that mounts on the TV. All help greatly appreciated. Tom
For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
Click to Enlarge
... then swing it out of the way for access to the alternator assembly
Click to Enlarge
View of the alternator electrical
connections-(A) battery positive, (B) field terminals, (C) wire harness
hold down, (D) ground terminal
It may be necessary to remove the alternator and mounting bracket from the vehicle as an assembly.
Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Click to Enlarge
Remove the front alternator assembly mounting plate from below the vehicle
Click to Enlarge
After removing the alternator assembly front mounting plate, remove the front engine-to-alternator bracket mounting stud
Click to Enlarge
Remove the two alternator bracket-to-engine mounting bolts Remove the alternator and mounting bracket assembly from the vehicle
Click to Enlarge
If re-installing, the alternator has a pivot bushing on the pivot arm that should be pushed out before installation
Mount a C-clamp and 18mm socket on the alternator pivot bushing ...
... then compress the C-clamp until it pushes the alternator pivot bushing out
To install:
Fig. 1: For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
Fig. 2: ... then swing it out of the way for access to the alternator assembly
Fig. 3: View of the alternator electrical connections-(A)
battery positive, (B) field terminals, (C) wire harness hold down, (D)
ground terminal
Fig. 4: Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Fig. 5: Remove the front alternator assembly mounting plate from below the vehicle
Fig. 6: After removing the alternator assembly front mounting
Fig. 7: Remove the two alternator bracket-to-engine mounting bolts
Fig. 8: Remove the alternator and mounting bracket assembly from the vehicle
To install:
The brake light switch is mounted to the brake pedal bracket assembly, under the instrument panel. The stop lamp switch attached to the mounting bracket.
