My baby lock dx froze up while sewing what do i do. while i was sewing all of a sudden everything stopped and i can not get hand wheel to move or needles anything, what do i do
Sewing Machine: Needle won't move
A disengaged clutch, broken drive belt or internal drive gear failure can prevent the needle from moving. Engage the hand wheel clutch if you have it disengaged for bobbin winding. If the needle won't move with the clutch engaged, unplug the sewing machine and check the drive belt. https://www.searspartsdirect.com/diy/symptom/sewing-machine-repair/1234596/needle-won-t-move/smac1011147
How to Fix Brother Sewing Machine Error Code E6
Q: What does E6 error message mean?
A: The motor locked up because thread is tangled
Q: How to fix E6 error message?
A: Do the following:
The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
The needle could be bent. Replace the needle making sure the flat side is facing the back.
If you are referring to the threading tubes, it likely needs to be serviced by your local technician. This repair requires taking the machine pretty far apart.
when you release the blade, sometimes you have to reengage it manually, turn it to unlock, machine off (safety only) push up on bottom of upper blade until it stops. turn hand wheel and watch if blade is moving. If not repeat. When it moves your good to go.
it sound like the feed dog & the presser foot need to be adjusted so they work togeather,,it's very possible they need to be timed a sewing machine repair shop can tell you for sure
In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
