SOURCE: lost the bugaboo cameleon manual - need to install seat
You can find the user guides on the Bugaboo website.
https://www.bugaboo.com/US/en_US/support/product-information-strollers
SOURCE: changing my bugaboo cameleon from carry cot to buggy
Watch the video, "bugaboo assembly" on youtube. The trick is getting the buckle over the silver pins. You actually have to bend the frame to secure the strap then pull out the frame so it is straight again.
SOURCE: The frame tilt seized on Bugaboo Cameleon
bUGABOO will send out free replacemnt buttons even if your pram is out of warranty you need to contact them. They will fix the problem but i had to put them in the oposite sides to what their instructions suggested for them to work so def a fiddly job but does fix problem.
SOURCE: Cameleon Jogger Stroller: The hinge on my bugaboo cameleon is stuck-in and n...
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions
to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins
shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for
this critical component is beyond me!
1/.
Remove the domed star lock washer.
This is the hardest part of the job. Most people try to leaver this off in the hope of re
using. First problem with this is
you will mark or damage the surrounding plastic second is star locks are not
intended for reuse and will never hold as well as when first used, so best find
a new replacement. A hardware
store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a
slot in the dome with an angle grinder and then use a large screwdriver to
prize off.
Note it is best to open and repair one side at a time, so
your moving and flexing one side of the handle does not dislodge parts in the
other side.
2/. The lock
mechanism is very simple; a wire rod rotates a plastic disk. The disk has two plastic pins that move
the locking rods in and out of the inner hub into and out of the outer
hub. You need to ether repair the
disk by drilling out the pin stumps and finding a replacement metal screw you
can fit / glue in. Or (my
preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble
handle locking hub and check operation.
(I use a small amount of the grease used for taps to give a smooth
action) If all has well fit,
the new star dome on the hub shaft and tap home. To protect the dome finish I
use a large socket from my socket set and an old rubber washer from a toilet
cistern.
4/. Repeat
operation on the other side. Note
the disks are mirror images of each other and are not interchangeable. Bugaboo calls the side with the brake
lever “LEFT” the disk will have a
serial number that ends with “L”.
I have had metal disks laser cut and stainless steel pins fitted. Cost of a disk with a new star dome
washer is $75 New Zealand. If you
like one or a set, you can contact me [email protected]
Regards
Steve
SOURCE: I cant fold my bugaboo cameleon chasis. how can i
I answered a similar question only yesterday. The sliver cap is a Capped Starlock do a google to find out more. They are a one use item and trying to remove them for reuse will mark the plastic hubs and make a weak repair. Here's my How to fix a Bugaboo Handle instructions If you are not a handyperson type, take these instructions
to you local Bicycle Mechanic or Small engineering shop. The bugaboo handle fault is caused either by two small
plastic pins shearing of a plastic disk that actuates two metal locking
rods or a broken locking rod. Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me! They are critical components with a history of failing! 1/.
Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in
the hope of re using. First
problem with this is you will mark or damage the surrounding plastic second is
star locks are not intended for reuse and will never hold as well as when first
used, so best find a new replacement.
A hardware store should be able to source some for you. Quickest way to remove a capped washer
is to carefully cut a slot in the dome with an angle grinder and then use a
large screwdriver to carefully prize one side up so you can fit a
screwdriver. Note the walls of the
aluminum hub axel are thin and easily distorted, make sure you only lever the capped
star lock and not hub axel. Use
one screwdriver as a support and another to lift off the capped star lock. Note it is best to open and repair one side at a time, so
other side. The hub and disks are
mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will
have an "L" after their serial numbers. 2/. The lock
mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will
have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another
frame to salvage hubs from. They
are held in by a single aluminum rivet. The disk has two plastic pins that move the locking rods in
and out of the inner hub into and out of the outer hub. You need to either repair the disk by
drilling out the pin stumps and finding a replacement metal screw you can fit /
glue in. Or (my preferred choice)
have a new metal disk fabricated that will last a lifetime. 3/. Reassemble
If wire rods seem to be in the incorrect position, loosen the top
plastic fittings where the handle extends from by removing the small
self-tapping screws and wiggle things into alignment. (I use a small amount of
the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on
the hub shaft and tap home. To protect the dome finish I use a large socket
from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side I have parts available laser cut metal disks with stainless
steel pins, replacement locking
rods in stainless steel and capped star lock washers you can contact me at [email protected] Regards Steve
