Question about Riccar Vacuums
Why does the belt on a riccar vacuum keeps coming off?
  • Riccar Master
  • 1,603 Answers
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Posted on Feb 04, 2017
SOURCE:
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Apr 07, 2014 | Riccar 8850 Vacuum
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
Dont owners manual
Get a new belt. If that doesn't take care of it, replace the rubber motor mount and metal pivot. Your vacuum is probably close to 20 years old and has some worn parts.
Jan 08, 2014 | Riccar Vacuums
How can I replace the belt on a Riccar Rad 8 model
Your belt should not need replaced unless it has over heated the belt somehow. It has a lifetime belt. There are screws on the bottom of the vacuum that allow the cover of the nozzle assembly to be removed to gain access to the belt area. It may be less cost in the long run to have it looked at by a Riccar repair technician.
Mar 30, 2013 | Riccar Vacuums
Riccar 8850 keeps throwing belt
Your vacuum is at least 10 years old. There are some inexpensive parts that can wear or may need adjustment. You have a very durable vacuum that may have many more years of life but Just like a car, needs to be serviced by a trained qualified technician who knows what to look for. It will save you money I the long run.
Nov 26, 2011 | Riccar 8850 Vacuum
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
Sep 15, 2010 | Riccar 8850 Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
My riccar vacuum does not pick up anything
Check the belt and then the tube on the side of the vacuum that runs from the bottom to up the side to the bag. If they belt is broken the vacuum will not pick anything up. If that tube is clogged up with dirt that will keep the vacuum from picking up as well.
Oct 20, 2009 | Riccar Vacuums
Vacuums Logo
206 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
