On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
If you feed the speakers a sub-audible tone, they will stay on and will not interfere with your notification tones. Use an online tone generator at <10Hz and make sure the system volume is turned all the way up. You may need to reduce the tone volume on the website to prevent pulsing of your notification tones.
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar hope this helps
Hi to adjust the volume of keypad tone you need to
Adjust the volume of the key tones
In Idle mode, press [Up /Down ] to adjust the key tone
volume.
Let me know if this will solve your prob
Remove the JBL badge on the front grill, insert the supplied hex wrench and turn counter-clockwise until it's loose enough to adjust the speaker, the turn the hex wrench clockwise to tighten it. If you don't have the hex wrench, you can use a long allen wrench.
The volume controls in these units are very prone to failure. The part number is 513-0046-00. JBL says they don't sell parts for these. I"m looking for a generic replacement.
