004-350
SOURCE: Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
SOURCE: Xerox M15 Prints dark only on copies
If your on maintenance tell them you want a replacement. If you have a maintenance agreement you are entitled to an identical replacement. Write a letter, with the serial number, peoblem and tellt them you want to exercise your TSG agreement. Total Satisfaction Agreement.
Not fixing it is rediculas.
SOURCE: Xerox Workcentre C2424 error code
That is a serious error code indicating hardware failure. Anything with a 07 is a major fault inside the machine. I am not seeing that exact error code referenced anywhere, but I can tell you that it is going to need service for certain. There is no simple thing you can do to get it back to functioning, unfortunately it will require a Xerox service person.
I am so sorry about that, if you really want to know what the error code is specifically referring to please reply here and I will continue to track it down for you, but thought I'd let you know right away that it is something major for sure.
Thanks
Tim
