Question about LG LMV1813ST Microwave Oven
LG LMV1813 F4 error code - LG LMV1813ST Microwave Oven
  • LG Master
  • 6,694 Answers
F4 means sensor open, You have to check the Humidity sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Feb 07, 2017
SOURCE:
My 6 year old LG above stove microwave is giving me an error message E-4 when I try to use reheat.
try unplugging the unit for about 5 min..... for the microwave to reset. Plug back in and try a microwaveable safe bowl with a little water for 30 sec. This may take care of the error message.
F4 indicates an open sensor
Jan 05, 2018 | LG Microwave Ovens
Why does my GE Spacmaker display an error code F4 without turning on microwave whatsoever?
If you wish to get some details microwave repair and Error codes ; check the site linked here. Pull up older posts...
Sep 03, 2016 | GE Microwave Ovens
Problem with LG LMV1813 ST Over Range M-wave
Please post a new help request and be sure to include the full model number from the tag on tjhe unit as well as details on your symptoms, such as what it's doping or not doing, and when & how the problem occurs.
Then we'd be able to give you free help.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
We've replaced a GE JVM2070 with an LG LMV1813 microwave. The unit is vented out the back, but when new unit installed with the microwave damper attached it makes a horrific noise. Wen damper is removed...
I would suggest that you carefully review the installation instructions step by step and be sure your filters are installed properly.
You should also inspect your outside vent cover and do an air flow test or visual inspection of the entire length of the ductwork.
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ultrawave with Hood fan
You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 04, 2008 | Microwave Ovens
LG LMV1813ST Microwave Oven Logo
709 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
