Question about JVC Televison & Video
Hi I have a jvc lt40n530 tv and I lost my remote .my daughter was playing with the tv n ended showing key lock on screen I can't change any channels only show what is currently playing
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
If its a smart TV download the app for the remote and unlockit
Posted on Feb 03, 2017
6ya staff
SOURCE:
TVtechmaniac
David Makowski
  • 140 Answers
SOURCE: jvc channel lock
The default lock code is "0000" Then you can go in and turn off the V-chip.
Posted on Sep 13, 2007
Anonymous
SOURCE: Channel display
try pressing the "i" button on the remote.
Posted on Sep 19, 2007
Anonymous
  • 52 Answers
SOURCE: TV locked up
Go into your menu. Sounds like your Parental lock might be "on". You should be able to solve your problem in the menu. Keever
Posted on Mar 07, 2008
Anonymous
  • 58 Answers
SOURCE: TV Locked
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Posted on Apr 02, 2008
Anonymous
  • 34 Answers
SOURCE: Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Posted on Aug 03, 2009
HOW DO I GET GIG1 OF MY JVC TV SCREEN
Is it a 4k set? If so, that is gig #1 input and you must use the remote to switch around the inputs to the one you have connected.
Feb 11, 2015 | JVC Televison & Video
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Green lock and black screen
go to your menu and turn off the ccd and text modes to remove the box,as for your lock out code try oooo or 9999.
Sep 22, 2008 | JVC AV-27D302 27" TV
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Televison & Video Logo
234 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
