SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: My CD drive (DVD RW) is not working. It fails to
You can go to the lenovo site (lenovo.com)
Clcik on support on the menu
Then choose download drivers
Enter your domel number, etc and choose the proper driver for your OS
Download it and install it.
That may take care of it. If not:
right click my computer and choose manage
click on device manager
Find your CD drive in the list and right click it
It may list "upadte drive" in that list. If not choose "properties"
There should be a tab called drivers - choose that one and switch your driver
Hope that works.
SOURCE: hi i got a new
click start control panel,display,desktop you can select a different desktop from the drop down list. hope i have seen you in Tnagar browsing centre. way long time back. Long hair.
SOURCE: My Lenovo ideapad Lapdop does not recognise their
hi,
try troubleshooting with 100% working battery, it most possiblity yor battery problems
Tq
SOURCE: forgot HDD password ,so please help to disable this on s10-3t
Go to www.ebay.com Type: HDD password and check out www.download.com same notation as above.
It shows the networks. It says password incorrect
Can't Do system restore. Cant see C drive
