There could be a few different reasons why your HiTi photo printer is not displaying on the monitor. Here are a few things you can try to troubleshoot the issue:
- Check the cables. Make sure the cables connecting the printer to the computer and monitor are securely plugged in and in good condition.
- Check the printer's power. Make sure the printer is turned on and receiving power.
- Check the printer's status. Check the printer's control panel or display for any error messages or indicators that may indicate a problem.
- Check the computer's settings. Make sure the printer is properly installed and configured on the computer, and that it is set as the default printer.
- Restart the printer and computer. Try restarting both the printer and the computer to see if this resolves the issue.
- Check for updates. Make sure you have the latest driver and firmware updates for the printer. You can check for updates on the manufacturer's website or through the printer's update feature.
If you have tried these things and the printer is still not displaying on the monitor, the issue may be with the printer itself. In this case, you may need to have the printer serviced or repaired by a professional.
I hope this helps! Let me know if you have any other questions.
