Chat bot
SOURCE: Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator
Please enter your ZIP Code:
CANTRELL SUPPLY INC.
2918 SOUTH COOPER F-2
ARLINGTON TX, 76015
(817)465-9121
11.1 miles
BRANCH VACUUM & JANITORIAL
SUPPLIES, L.P.
12895 JOSEY LANE #122
FARMERS BRANCH TX, 75234
(972)247-5838
15.7 miles
FORT WORTH SHAVER & APPLIANCE
1900 MONTGOMERY STREET
FORT WORTH TX, 76107
(817)335-9970
16.3 miles
AMERICAN VACUUM CO.
5545 W. LOVERS LANE
DALLAS TX, 75209
(214)357-8419
18.2 miles
KIRBY CO. OF DALLAS
4118 MAPLE AVE
DALLAS TX, 75219
(214)526-7951
19.0 miles
BRUNER KIRBY CO., INC.
5608 MC CART AVE.
FT. WORTH TX, 76133
(817)292-8421
19.4 miles
VACUUM DEPOT
5359 WEDGEWOOD
FT WORTH TX, 76133
(817)292-4472
19.4 miles
MODERN AMERICAN MAINTENANCE
8545 CAMP BOWIE WEST
FORT WORTH TX, 76116
(817)244-0919
19.9 miles
ALL VAC, INC
4451 LOVERS LANE
DALLAS TX, 75225
(214)521-2558
20.2 miles
KIRBY CO. OF DESOTO
104 N. HAMPTON ROAD
DESOTO TX, 75115
(972)223-4029
23.8 miles
AAA VACUUM CLEANER CO.
9845 WALNUT HILL LANE
DALLAS TX, 75238
(214)348-1620
25.0 miles
BROADWAY VACUUUM
4401 BROADWAY BLVD
GARLAND TX, 75043
(972)240-7971
31.1 miles
THE VACUUM DOCTOR
500 NORTH GALLAWAY - STE. 10
MESQUITE TX, 75149
(972)329-1104
31.4 miles
CHAMPION VACUUM, INC.
8809 LAKEVIEW PARKWAY #128
ROWLETT TX, 75088
(972)463-2755
34.3 miles
VACUUM & SEWING DR. OF TERRELL
811 WEST MOORE, SUITE E
TERRELL TX, 75160
(972)563-0330
49.8 miles
var prm = Sys.WebForms.PageRequestManager.getInstance();
prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity);
prm = null;
function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() {
var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity');
var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter'));
elAct.style.width = bounds.width + 'px';
elAct.style.height = bounds.height + 'px';
Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y);
Locating Stores...
SOURCE: how can i clean the hose of my bissell spot bot?
Well... it's sub optimal but this is what I did, run hot water into the sink, add a few table spoons of bleach and run the hose along the edge of the water to slowly **** it into the hose (the tank fills very rapidly and the auto shut off will activate). You will want to run 4 or 5 tanks of waste to get the bulk of the gunk along the walls out and this will also get rid of the serratia growing (red stuff). If you dangle the hose in a u down the front of the sink and shut off the machine you can catch about a pint of water and bleach solution in the hose and roll it around inside the hose then let it sit for awhile and finish by sucking it into the waste tank, not perfect but my hose is much cleaner.
SOURCE: clogged spot bot
There is a very small, white water filter (approx. 3/8" in diameter/
1/8" thick) inside the "seat" where the solution tank connects to the
machine itself. Could very well be your problem if you are in a city
environment, or any other situation where hard water is present. This
is a very easy fix; discovered it when my wife experienced the exact
same problem.
1) Make sure other causes have been eliminated, such as clogged nozzles, etc. (Refer to owners manual.)
2) Ensure that the solution tank is indeed seating properly with the
machine, (a few small bubbles rise from the connection once made.)
3) Remove solution tank. With needle nose pliers or a very small
screwdriver, GENTLY remove the white filter from the black, movable
"seat" connection on the machine.
4) Run the machine on manual (without the filter) to determine if this
is indeed your problem. (Don't run for an extended period of time this
way if this actually is your problem. The filter is there for a
reason!)
5) Simply wash the filter gently between thumb and fore-finger.
Vinegar may be used, but simple tap water works as well. If clogged,
you should feel grainy, hard water type scale/ lyme build-up when
cleaning the filter.
6) Recycle the original filter or replace if necessary. (It would be
very easy to make a new one without going through the hassle of dealing
with OEM parts or Bissell. Just go to your local hardware store and
they should be able to help you out with no problem.)
Voila! Spotbot works again.
Hope this helps!
SOURCE: Facebook problem from a downloaded bot
The solution is simple...I had the same problem and i solved it.Download spybot search n destroy...Its free. Make the updates. Shutdown the pc run safe mode pressing f8 before mem checking.
Now run spybot in safe mode to clean everything inside.Don't forget to immunize your system not just clean.
When its finished restart the pc in normal mode.
Then go to C:\WINDOWS\system32\drivers\etc\hosts
Here is the problem!!!
With right click to the file (hosts) unmark the "only read". Now right cLick and "open with" notepad.
Now mark everything inside and delete them all!!!
Save the file empty. Restart the pc and you are ready!!!
If you have restrictions set for location services, anytime the app ask to use this service, it will not allow it to be added to the list. Turn "allow changes" on and try running app again.
You think abouthttp://Aztekium.pl/Bot
Right?
