It then prompts me: "To change the no answer greeting (press 1), to change the busy signal greeting (2), after hours greeting (3), caller ID greetings (4), temporary greeting (press 5)." I have tried recording on all of these and then I select accept at the end. Then I call and it's the old voicemail again! Please help me.
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
SOURCE: How to change the answering maching message
Depending on how your automated attendant is programmed, you will need to either change certain prompts or certain Custom Service menu greetings. Without knowing how your system is configured, I can't be more detailed, sorry. However, we can fix this for you over the Internet with our remote support package...
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: Trying to change our company greeting
When you record it, you press 1 immedately to stop recording. From there it will say press 1 to review and 2 to accept or 3 to record again or something like that. You need to select 2 to save.
Carl
SOURCE: PIN Number
O.K. Here's your solution, but it's only available to you until next Monday. Go here http://public.carl.airpost.net/ and get both TDA EXT PIN files. One is the extension users guide and the other is the admin sequence to reset it. Please comment and/or rate this solution so I know you have it and I can take it down earlier.
This is one of the codes that can't be posted in a public forum.
Carl
SOURCE: Can't find how to set my voicemail message on Panasonic KX-T7431
Thanks for all the helpful information! First of all, I think you have a TVS/TVM voice mail system. That's good, but what does the lady say when you dial 265 or 165 from either your phone or a phone that works?
If you have voice mail set up, the prompt would be to "Enter your password then #" or "You have X new messages" if you don't have your password set. If you don't get ANY of those on your phone, but do on someone else's, you don't have a mailbox.
Mailboxes are added from the System Owner's mailbox (999) by
option 6 then 1. Once you have a mailbox, you do use option 5 and 3 or 2 or 1 for Name, Password, and Greeting.
Since there is little difference between the models of voice mail, I have attached a TVS-50 manual. The instructions for adding a mailbox start on page 280 (or use the System Manager's Guide tab on the left).
http://public.carl.airpost.net/TVS/TVS-IM.pdf
With any luck, you'll get voicemail too :-)
Carl
