I have a Verizon QIP 7232 2 DVR box and an ONYKO AV receiver TX SR313 and a Sharpe TV
SOURCE: Direct TV DVR Receiver R15 Code
Try using the remote's "search" feature. If that doesn't work then it's probably not compatible.
Hope that helps...
Geno
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
SOURCE: genesis mx-900
I have the same remote and need to reprogram the remote too.
Genesis X900 has anyone had any luck finding out how to reprogram this remote yet?
SOURCE: RCA D771 universal remote won't work on Direct TV receiver
You have to use the aux1 button. Which is says in the instruction manual ! I had to do a code search, but works just fine now.
