Question about Makita Drills
Where can I get a circuit diagram, of the MAKITA DC1414F battery Charger's Circuit Board?
    Top Expert:
  • Makita Master
  • 52,794 Answers
Request the diagram directly from Makita.
Posted on Jan 28, 2017
SOURCE:
Dc1414f charger does not work anymore how to get the charger back charging again
  • BEWARE ! In recent years, on marketing technical reasons loader print separately orderable significantly
    more expensive than a new complete charger with many brands.
  • Panasonic Festool Bosch Dewalt can have on a different base a Replacement powerprice , but sometimes most in the budget range its better to buy it complete new. its oft cheaper.
  • If On download page below the picture you see the word processing .... wait be pati?nt until there pop upped the word Get Manual underlined in stead of.
  • MAKITA DC1414F BATTERY CHARGER Service Manual free download schematics...
Apr 19, 2015 | Makita 6916fd Impact Driver & Dc1414t...
Rebuilding makita battery instructions
Rechargeable batteries are almost never worth rebuilding and never last very long when they are. In some cases, Makita being one, if the circuit board in the battery detects something wrong with the battery, it 'bricks' the battery. This is not resettable and the battery will not charge on a Makita charger. I'd be looking to get my money back from the repairman since his rebuild didn't take.
Jan 16, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the...
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
May 16, 2010 | Makita Drills
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
Dec 16, 2009 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drills Logo
605 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
