SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
SOURCE: Maytag Front load washerMAH8700AWW.
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
SOURCE: What is the error code dS for Neptune Maytag
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
SOURCE: Maytag Neptune Model# MAH8700AWW during wash
Hi, let me first of all correct you, there is no F3 error code on the Maytag Neptune, rather it is "E3"
"E3" code - Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of 'E3' codes: 1. Spin drum stuck - Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose - When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an "E3" code in the worst case, or "SUdS" if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor - PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
