SOURCE: royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
SOURCE: Keep getting error code E07-27
E07-27 is a problem with the finisher tray lift motor. Make sure that a trash can is not under the tray. Have also seen screws work there way loose causing the tray to bind. If neither is your problem, you will have to call a service provider. Temporarily you can turn the power off, separate the finisher from the machine, unplug the connector, and turn power back on. You will not have a finisher but you can make copies until it is serviced.
SOURCE: Error Code E07-27 How can I fix it myself ???
That error is a finisher tray lift error. If you do not see anything binding the trays, service will have to be called or finisher disconnected. Pay attention to the screws, they can loosen causing the trays to bind.
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Testimonial: "thanks "
SOURCE: my saeco royal professional has no power, no lights. What's up?
Hi
First I would check the switch on the bottom left side of the machine and make sure that it has not been turned off.
If it is on you may have a fuse out on the board. It is a very special fuse. It is a 35Ma timed lag fuse When we change them we put in a 50Ma Timed lag fuse with no problems, because the 35MaT is hard to find.
