SOURCE: Do you need to remove
no absolutely not. you may have tight spaces to work in but do not remove the engine.
SOURCE: which oil to use gilera nexus 500 2004
Standard bike oil use SAE10W/40 or SAE5W/30 Castrol, PenRay, Motul, etc Use SAE70W90 single grade. Good enough free advise?
SOURCE: fork seals on gilera nexus 500
HI HOW GOOD R Y ON TOOL S TO DO THEM BIT OF A PAIN SEE HOW MUCH BIKE SHOP WILL COST GOT MY DO FOR 70 ALLIN . BUT REMOVE FORKS
Stop using until you find out as if it is a oil pressure problem
Wear and a seized engine can happen not the sort of the thing you want to happen
