www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E...
Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
What's the problem??? I think you pretty much explained it yourself...the engine has been overheated! You most likely have damaged cylinder heads and/or cylinder block, pistons, crank shaft, cam shaft, etc.. I would recommend having it checked by a professional to see if it is even worth repairing or if the engine must be replaced.
@ items of concern spark or fuel. For spark as you crank the engine ,assuming that you have a tach on the dash.Does the tach show movement(this will be very small) if it does you have a fuel problem if it doesnt then you will need a crank position sensor
