Being that it is a Dynex, an off brand, i would toss the TV on craigslist and if you get $40 for it take the money and run. The general rule of thumb is that if you can repair the TV for less than half of the cost of a new set, you repair. If the repair cost is more than half of the cost a new set, you replace. But you also have to factor in the age of the set, brand, and whether or not it has sentimental value.
Try Nokia default security codes. It is 0000 or 1234 for basic phones. but dont know for high end models like N70.If default codes doesnt work you need to get the Master reset codes from any shop or online.
On the main screen type
*#06# for checking the IMEI
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the
information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Code (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase
battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically
restart
yes surely its the flat cable or commonly called flex cable or ribbon connector is already have a cut or damage bring it to samsung it is the of your phone.
Your problem could be due to a "bad" tube or any one of a long list of other things. Typical repairs would likely run at least $75, and you could spend that much replacing tubes. Unless the set has high sentimental value it's probably not worth fixing. I don't show any "A" series RCA sets, so I can't validate the set's age or value.
