Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I Have a Nikon D40 DSLR and a Vivatar zoom thyristor flash unit. I want to fire it off camera in a dark with my shutter in bulb setting when sound is made. any Ideas?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
I should add to my answer to your other post, that in a long exposure you can also fire the remote flash manually.
Posted on Jan 25, 2017
SOURCE:
I have a Nokon D40 DSLR and a Vivatar Zoom Thyristor 3500 flash that I want to fire off camera to capture high speed photos.I would have the D40 in dark room with shutter in bulb setting. any Ideas
You can either use a PC cord to connect the flash and camera, or you can use a remote trigger to fire the flash cordlessly. Your local camera store should be able to provide options for both.
Jan 25, 2017 | Nikon D40 Digital Camera
285, red/green lights blink, whines on start up, but won't fire
Hi Dave,
Try shorting out Center Pin to Outside Metal Contact after the light turned green. This must fire the flash.
If not, could be the flashtube /or trigger are defective.
Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Vivitar 285HV Flash
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Can I use my old auto thyristor 550FD on my new Nikon D90 DSLR
No. The high trigger voltage in your old unit will damage your D90 for certain.
You need to get a newer flash (US=strobe) designed for digital cameras but don't have to stick to Nikon's overpriced offerings. Metz are excellent and have a high resale value as you can change the dedication model to suit different manufacturers.
Oct 05, 2009 | Nikon D90 Digital Camera with 18-105mm...
Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
May 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
Sunpack pz40X II flash - compatible with Nikon D40?
hai i think u told only sometime....
may b ur settings are not rit in the cam.
Jan 07, 2009 | Sunpak PZ40X II TTL Flash
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
60 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
