Question about Canon PIXMA MP530 All-In-One InkJet Printer
Cannon MP530 scanner won't scan document it shows error code
I have been trying to scan a document with no success. I have checked the plugs, made sure the covers are closed properly..all to no avail. Error code 2,155,0 keeps showing on my computer. The scanner moves a quarter of the way down and stops completely, while the screen on the front still shows "scanning" but there is no movement from the scanner and the error code pops up on the computer screen. It photocopies and prints, but will not send a fax or scan.
  • 43 Answers
Hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Posted on Jul 22, 2009
SOURCE:
Cannon error codes
Printer is in use or an error has occurred. check status. Scanner driver will be closed.
code 2,140,2
if scanner is not in use there is a problem using it with the USB unplugged.
May 15, 2013 | Canon PIXMA MX892 multifunction printer
Every time I try to batch scanning on my Pixma MP530 I get a vertical line running through the page. I've cleaned the platen glass, the inner side of the document cover, the transparent sheet (I even...
When using the ADF to scan multiple document the scanner assembly stay stationary and the paper is fed across it. Where the scanner parks for this there is something between the scanner and the document, likely on the glass. Often there is a small strip of glass on one end of the scanner bed. Clean here if there is one, otherwise look around and I'm sure you'll find it. Remember, never spray cleaning solutions directly onto the glass, always onto a cloth or towel first. The scanner has a calibration strip that can be damaged otherwise.
Feb 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
Aug 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I add multiple pages to one scanned doucment?
Open your Adobe Acrobat (e.g., 9.0 Pro), load your pages into the document feeder (fewer than 30 at a time), then ask Adobe Acrobat to create PDF from scanner (File/Create PDF/From Scanner). Canon MP530 as the scanner and click OK. Works like a charm!
Jul 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scan error with HP Photosmart C4480
Please try "Scanners and Cameras" which comes with Windows to see if you can scan images successfully from your scanner.
_______________________________
Catherine Sea
Dynamsoft | TWAIN ActiveX/Plug-in
Feb 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Cannon MP530
Hey, so if you already have everthing else working, drivers installed and so on. Lets try scanning a document, this should work if everything is installed fine.
press start
select run
(if your using windows vista just hold down the windows key and press r to open the run menu)
type in mspaint
now that you have paint started, click File and from scanner or camera
if a document gets scanned fine, (follow on screen instructions) then we can look at optional software to scan documents, if paint is not enought.
Thanks,
Ekse
Sep 01, 2008 | Office Equipment & Supplies
Error code 2806:0000
your scanner soft has problem try to another driver install it try to scan
Jul 10, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
818 people viewed this question
Clive
Clive
old marine
old marine
Ekse
