you need to change the battery, the time it has sit without charging has weekend the battery. Maybee try to check the acid level and refill with boiled water that you first cool down to under 30 celcius and then recharge the battery.
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
SR indicates there has been a power interuption. If not from a quick power outage, I suggest having a qualified Service Technician che for a loose connection.
The Sr error code means that there is a stuck relay on your main board. Would request you to replace your pc board. Let us know if you want any further clarification.
Thanks for contacting fixya.com
