A
Anonymous Posted on Jan 23, 2017
Hi! How to factory reset Sony DA4300ES
What is the key combo on interface to release memory and return to factory settings?
Marvin
Level 3:
Top Expert:
  • Sony Master 85,242 Answers
  • Posted on Jan 23, 2017
Marvin
Sony Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058505
Points
266281
Hi Hi i forgot the password to my samsung galaxy note 10.1 2014 eddition
No problem follow the steps bellow to factory restore you Galaxy note 10.1
- Turn Off your Samsung Galaxy Note 10.1 device.
- Wait for 10 seconds, Then move to the next step.
- Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
Notice: The Hard Reset / Factory Reset operation will delete anything that are saved in your phone's internal memory, So make a backup of your data in case you can access them.
How to reset a samsung galaxy prime that is locked to gmail account with forgotten password
This will return the phone to factory settings with NO account.
This will also delete EVERYTHING on the phone.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  3. When the Samsung logo screen displays, release only the Power key
  4. When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  5. Press the Volume down key several times key to highlight 'wipe data / factory reset.'
  6. Press Power key to select.
  7. Press the Volume down key until 'Yes -- delete all user data' is highlighted.
  8. Press Power hey to select and start the master reset.
  9. When the master reset is complete, 'Reboot system now' is highlighted.
  10. Press the Power key to restart the device.
Sony ericssonX10i forget pattren andcan do emergency call only for sloving.
Soft Reset
If your Xperia Z Series is frozen and not responding when pressing on buttons or tapping the screen, try a soft reset. A soft reset will not wipe any data from the device.
  1. Open the SIM card door cover on the side of the phone.
  2. Use the end of a paper clip to press the small "OFF" button until the device vibrates. The Xperia will shut off, allowing you to restart.
Hard Reset
If you wish to return your Sony Xperia Z Series smartphone to factory default settings, a hard reset is the answer. If you perform a hard reset, it will wipe all data and settings from the device. You may wish to perform these steps if you've been experiencing lock ups or other types of malfunctions, or if you will no longer be using the device.
Note: If you think you may need any information stored on the phone in the future, be sure to backup the data.
Option 1 - Hardware Buttons
  1. With the device powered off, press and hold "Power" and "Volume Down".
  2. When the "Sony" screen appears, release both buttons.
  3. The Recovery screen will appear. Use the volume buttons to toggle the selection to "Factory Reset", then press "Power" to select.
  4. Use the volume buttons to toggle the selection to "Yes", then press "Power" to select.
Option 2 - From Android OS
  1. Open "Settings".
  2. Select "Backup & reset".
  3. Tap "Factory data reset".
  4. Select "Reset phone".
The Sony Ericsson Xperia Z Series will then go through the process of formatting the memory. Wait for it to restart and factory default settings will be restored.
Reset HP 17b11+
According to the manual:
To reset the calculator, hold down [CLR] while pressing the third menu key from the left. Repeat if necessary. The calculator displays
MACHINE RESET to confirm that reset has occurred.
The above sequence does not clear all memory and settings.
If you want to completely erase the continuous memory and return to default settings, press and hold down [CLR], the leftmost
menu key, and the rightmost menu key.(Press three keys simultaneously).
When the three keys are released, the calculator displays MEMORY LOST.
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
2answers
How to take the tv back to original factory settings
Unplug,replug the tv back about an hours later.All the tv settings,will return back to the tv original factory settings.
3helpful
How to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 • Cell Phones
Privacy lock hiptopq700 forgot how do i fix it ??
Hi.
You can do an hard reset. This will reset all settings to factory and erase phone memory. It won't delete data stored on SIM:
1.Remove Sim card and memory card
2.press and hold down the "R" button
3.Insert battery Into the phone while you keep holding R button.
4 When the display comes on release the R button and allow the phone re-booting
5. Put the SIM back into the phone.
Other way to release the lock is by holding down the letter L button and the Menu key at the same time. In this case the phone will not get reset, but the lock should temporarily release access to the menus. The function availability depends on settings. You can give it a try before resetting the phone.
Regards.
Ginko.
Mar 22, 2011 • Cell Phones
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
