I also have a Kokak C330. Yesterday I put an 4 gb SDHC and then realized it wasn't compatible. Today I exchanged it for a 2 gb SD card and I get the "memory card is full" error message. When I put this same card into another camera it works just fine. No matter what card I put into the C330, I get the same message. Did I ruin the camera by putting the SDHC card into it?
SOURCE: new memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
SOURCE: 2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
I have solved my own problem. I put a 1 gb card into the C330 and it works just fine. It would appear that the C330 won't run on a 2 gb card.
Why repost a question EIGHT YEARS (shouting intentional) after an answer has been found ?
