Those blinks are fault indications. From the number of blinks, you can get an idea about the fault circuit part/board. If you wish to get more details, visit the site linked here. http://electronicshelponline.blogspot.com/ Blinking codes and details of many brand devices are given.
Search the site. Type in the brand name of your device in the search box at the top of the display window, to get gathered all the related posts.
SOURCE: Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
SOURCE: I am getting vertical lines scrolling up on my new
Call for warenty service,prob. with ur backlight video board.
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
SOURCE: My Panasonic TC-P42G10 Plasma TV red light blinks 14 times.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Pansonic Plasma s are given in detail. Pull up older posts there.
