Tablets & eReaders Logo
j
joooodie Posted on Jan 23, 2017
How do i reset my iPad that's currently disabled and won't let me connect with iTunes?
My iPad is disabled and is telling me to connect with iTunes, yet when I do just that iTunes tells me to use my iPad to connect. Now I really don't care if I lose all my apps or songs I just want to fix the problem.
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on Dec 08, 2011
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Anonymous
  • 53 Answers
  • Posted on Feb 23, 2012
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
A
Anonymous
  • Posted on Jul 16, 2012
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Tankee
  • 11 Answers
  • Posted on Aug 17, 2012
SOURCE: Transfer video from ipad to pc?
you neen't waste your money, try this app, it's free: Leawo iTransfer
Harrie
  • 6746 Answers
  • Posted on Jul 21, 2014
SOURCE: I can unlock my iPad its disabled in it say to
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Perhaps you even could try this? How to Reset Forgotten Password for an iOS Device
I forgot my unlock code for my old ipad1 haven't used in in months
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Ave a lock screen on my Ipad and cant remeber my apple ID
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPad with iTunes.
Step 4. In the Summary window, you can see the option "Restore iPad". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
5answers
How can i transter pictures from my disabled ipad to the laptop?
If the pad doesn't work then there is no way to transfer the pictures that I know of.
1helpful
3answers
How do i fix my disable ipad
Go to iTunes then sign in, connect your iPad to the PC/Laptop and factory reset the iPad, that is the only way it can be done!
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
2answers
Ipad A1396 is disabled its sayes to connect to itunes but itune
The intent is to connect your iPad to a computer that is running iTunes.
You must have a current version of iTunes that knows about iPads and an operating system that can run the current iTunes. If your need to upgrade, be sure to install the OS first before your install the iTunes.
3answers
How to fix MY Ipad which says IPAD IS DISABLED CONNCT TO ITUNES I still do not know what to do next
This sounds like a password lock, but that is an assumption. So based on my assumption, you'll need to plug the cable into the iPad, then into a laptop or tower PC. Start iTunes on the laptop or PC, once iTunes has started on the computer you have plugged the iPad into, you should see some on screen instructions, follow each step closely. This should resolve your current issues. Hope this has helped.
How do I unlock a disabled ipad 2?
First try to reset the iPad, by pressing both the home button and the on / off button, till the apple logo comes on the screen. Then try again. You should have a password for you Apple account, because that will be asked. If you don't have an account name for the device not worth trying, because it will be blocked anyway.
If this does not work, why not try one in this link?
I forgot my password and now my mini ipad is disable
it's now in DFU mode and must be plugged up to the computer and connected to iTunes.
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
