Computers & Internet Logo
Ben Gates Posted on Jan 22, 2017
Samsung un32eh4000f no power, no light, nothing. Replaced power supply, now has power, lights, sound, acts like it turns on but no back light or anything on display. Replace motherboard, same symtoms
Samsung UN55KU6500F with no sound and no picture
With the cable unhooked that goes from power to main board that only tells the backlight section of the power board is working without regulation or overload protection, I suspect you have some bad lamps and overload or over current is shutting it down, of the issues I see with no backlights on Samsung sets about 95% of the time it's the backlights causing the issue
Samsung model un46eh5300fxza no sound, no picture, no back lights. When turned on red light blinks 5 times but nothing happens.
1. disconnect the cable between the power supply & the main board, if no back light, replace the defective back lights LED strips inside of the panel.
2. If the back light are light up, i will try a new main board.
I have a Samsung tv Model # UN46EH5300FXZA Video went blank then shut tv off then turned back on no video or sound. Replaced power supply board and main board no change.
Disconnect the cable between the power supply & the main board, if no back light, replace the defective back lights LED strips inside of the panel.
I have a Samsung UN39FH5000FXZA TV with no picture but sound. With a flashlight I am able to see the picture on the screen. I replaced the LED driver/power supply board and have the same problem.
I will test the back lights first.
To test the back lights, you need to disconnect the cable between the main power supply & the main board, apply the AC power to the power supply, if the back lights are not light up, the back light are defective.
No Picture on Samsung Tv model UN40EH5300f. Standby light is now on after installing new power supply. Need help on which part to buy now, inverter or mainboard?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
My Samsung TV won't stay on wut to do ok I turned it on today and it normally works but not now it has sound but nothing else
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung CLP-300 Laser Printer no power light
Dear
pl. check the power supply(SMPS), It can repairable, mostly the electrolytic capacitor for power storage gets damage. Also it may be replaced with a new one.
Thanks.
Hi We have a Samsung Tv LE40A656A1FXXU flatscreen keeps sticking in stand by mode. The red light is flashing and sounds as if its turning on but takes a while, eventually it does come on and all is fine...
The problem is that there is a bad capacitor on the power supply board of the television, it is still turning on because it is not yet completely bad. While it tries to respond is when you get the clicking sound, therefore it is going to keep acting that way until the bad capacitor is replaced.
Run a check on the power supply board, you will definitely see the bad capacitor, have it replaced and the television will turn on after reassembling the television back together.
Thank you for using fixya
Caseytech
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
