Vizio E500i-B1 50-Inch 1080p Smart LED HDTV Logo
r
rich cornwell Posted on Jan 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vizio model E500I-B1, SERIAL LTY6PLYQ5254714 that I'm having some issues with.. it seems to have intermittent back like issues. can anyone advise me where to start?
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Jan 24, 2017
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994607
Points
237762
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
Upper right quadrant of my Vizio TV is dark!
This model had issues with cold solder connections going from the power to LED driver board, I think you will see the issues once you remove the power supply, the 2 boards plug directly into each other, its the power supply plug that gives issues
VIZIO E500i-B1 broke again a month after replacing the power board. Having similar issue
You might want to check the VIZIO website for help. Given how cheap even 4K UHD TV's are today, probably not worth fixing again. Unless under warranty, of course.
Vizio 60" smart tv screen bottom section of the screen is lighter than the top
Sounds like you have some bad lamps in the panel that need changing, in time the backlights will totally go out and the set will have a black screen
1helpful
What causes an intermittent problem with the main board on a vizio e500i-b1 50" LED TV?
it can be a processor fault, or software fault. check the manufactures web page for your model and see if there is an update for the software.
Replace wifi module on Vizio E500i-B1
If you wish to get some details; check the site linked here. Pull up older posts.
2answers
My vizio will not turn on. The light on the bottom flashes on and off, but nothing on the screen. I replaced the main board. It worked for several days then went right back this issue.
Have just looked on you tube , I typed in fix for VIZIO E500i -B1 power off and a 2.24 minute video appeared . if that does not solve your problem type the product info and fault again and check the videos that pop up . hope this info is of use to you....
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
