A blinking red light on the power button of a Hisense 55 inch model 50R6E3 TV could indicate a problem with the TV's power supply. It could be caused by a malfunctioning component, such as a blown fuse or failed capacitor, or it could be an indication that the TV is overheating. In some cases, a blinking red light can also indicate that the TV's firmware is not up to date and needs to be updated
hello, check if your headset has inbuilt wireless connection technology or not.
If it has, you can easily connect your Bluetooth headset by using your TV's on-screen display. Using your TV remote, locate the accessory menu for your television, then access the Bluetooth settings, and set the pairing mode.
Switch on your headphones and set them to pairing mode. Your headsets will be displayed on your TV as soon as they are detected. You will then have to select your headsets in order to complete the pairing process.
It doesn't have, you need to use a Bluetooth Transmitter. As long as your TV has a headphone jack, then you will be able to connect Bluetooth headphone with TV by using a Bluetooth transmitter. Just make sure you get a Bluetooth transmitter and not a receiver because you are transmitting sound from the TV Source.
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
