Data tape drive.40
wow a blast form the past.!
im and old SCSI expert, from the old server days, high end.
and tape, wow, a working still tape drive?
why not get it at hp.? join there forum and ask, 1000x better than here, for sure.!!!
omg, hp.com shows, DAT is dead. (expected)
fell off the end of the "BLAST from the PAST" of technology.
like F104 jets./? and Cuba crisis.
i'd love to see it work and make those funky sounds again.
cute.
what good is it, max was 40gb. for data,compressed 20 not.
i'd buy and use. blu-ray DVR
and external e-stat 1TB drives for archival
btw you nee d a matching SCSI card,to make this play
can be had dirt cheap,
I have SCSI 1 CARD (isa) From mid 1980s framed on the wall
for fun.'
next to my framed real mag core memory bank. hand wound.
next to and 8 inch floppy.
SOURCE: scsi tape drive
Hello Rivcr, 1. Check for a terminator on the back of the scsi unit. 2. Make sure you have power. 3. make sure power switch is on. 4. Select a different scsi id number, not 0 or 1 or 7. Does this help?
SOURCE: I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb
wheel
Rotate thumb wheel
counter-clockwise until you feel resistance. Wheel may spring back when you
release it. This is OK.
Locate hole in bottom of
drive. Insert #10 Torx driver and rotate clockwise until tape
ejects. If there is a lot of tape on the take up reel, this could take some
time.
Rotate thumb wheel
clockwise to eject the tape.
SOURCE: forgot service password for HP Surestore Tape Autoloader 1/9 DLT
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
The display shows a
valid date and time
Do the following:
NOTE: As an example, 2000
02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers:
(2 * 1001) + (7 * 101) + 2 + 2000 = 4711
4711 * 123 = 59453
Convert all digits to be between 1 and 4 = 131413
Add the leading 1s to make it eight digits long -
11131413
SOURCE: 4MM Dat Tapes - not
You're not gonna like it but here it is - the information on those tapes cannot be recovered easily: the old tape unit had its heads slightly misaligned and the data was written on the tape also misaligned so it's not readable on a new unit. The only way to recover the information is to try to replicate the misalignment in another unit and that will be almost impossible - it involves manually adjusting the angle of the shaft of the rotary head by fraction of a degree.
